I now have a 34" UM65 from Germany (at the 3rd attempt
I will post some pics/thoughts later but so far:
Good:
No dead pixels at all. I painted red,green,blue,black,white full screen not a single dead or lazy pixel appeared.
Audio is way better than the Asus 21:9 screens (although I use a high end Altec Lansing THX 2.1 system for audio or headphones).
No backlight bleed I could detect I will look again when its dark but if its there I cannot see it.
IPS glow is minimal & hard to spot but again I will have to view again when its dark later this evening.
Bad:
No UK plug in the box had to rip up the euro plug & convert to UK its 3 wires so just a case of cutting off & rewiring a UK plug.
Size/scale is a lot smaller than I expected coming from a 28" 16:10 its wider obviously but I expected another few inches scale wise (even though I knew the measurements in advance).
Needs propping up another 2" or so its way too low on the stand which is also super flimsy its really cheap plastic hope it does not break!
Good:
Bad:
