So virus you have gone from being really annoyed with OCuk for an old chip to being really happy you have a good chip?
yeah i dont know what to make of that lol
its probably cause i jumped on the bandwaggon of people that said the L3 chips where crapper and hotter.
Boomstick
You know you have a cherry.
Stop trying to create the impression that all L3's should run as your's does.
Most do not, as well you know.
My 'L3' has low stock voltage and reaches 4.9Ghz no probs. If anything the L3's seem to be better![]()
What volts have you settled on at 4.9Ghz? Stable too?
I know you posted them earlier in the thread but I wondered if you've improved it at all?
Boomstick
Really pleased with my L3 so far.
Idling at 28c and watchdogs, BF4 and Autosport dont push it over 59c
Currently at 1.2v and going to up the turbo ratio later to see if I can hit 4.8+
Mines is batch# L336D106 and does 4.9ghz (although not quite tweaked it enough to get fully stable). Does 4.8 at 1.31v fully stable.
I only bench @ 4.9Ghz 1.38v.
24/7 use is 4.6Ghz @ +0.50v gives 1.26v.
My i7 4770k 4.6ghz is at 1.266v to stable I do wont the dc chip but because again with silicon lottery not sure worth it even after selling mine.
Not seen many chips so far that are 5ghz 24/7 capable on reasonable voltage.
