If any of you want this and use steam trades you can get this for under 11 quid
How, do you need a russian steam user to send you it or something ?
Just read a few threads on the AC forums, its not an issue, its just the way the game GUI is designed.
Can't believe it. Bought this only discover my graphics card isnt compatible![]()
What is your graphics card?
AC is designed around DirectX11, but it can be ran on dx10 cards, albeit with "square" trees.
Steam\steamapps\common\assettocorsa\system\cfg\dx11.ini
ALLOW_UNSUPPORTED_DX10=1
can't believe they have automatic braking too.... /sigh.... almost as bad as dirt 3's throttle/brake/steering assists
where's the fun in that.....
or maybe I read they were going to bring it out in time? or that they were developing it but calling it something else not to infringe on copyright or licensing or something?
booo!!! gotta work out some good FFB settings too. (also found out I had to invert my pedal controls too.... by pressing the brake it released it and the car would go shooting forwards as no gas = all gas xD )
considerate...yes...safe......debatable
just need to get used to it then I'd be up for some races
