Yeah well I'm using Killer Xeno network card, the cable seems fine just the connector clip is broken other than that its all good.
Ok now I'm connected straight to SH2 with 152mbps that's been installed today but I'm still getting around the same speed of 85-90mbps, its weird. Though the SH2 is downstairs so I'm like running a long cable, could that be the problem?
Long cable shouldn't be a problem if it isn't damaged anywhere. I'm running a couple of 25m Cat 5e and get gigabit no problem, you could easily go further than that though.
Go to your Network Connection's properties and check if it's connected at 100Mb or 1Gbps.
Or check the lights on the ethernet port on the superhub... Orange = 10/100Mb, Green = 1Gb.
