Talking of PSU what do you reckon min I an get away with would be? I'm thinking 550 with a 290, 46/4790k and one or two HD.
Was actually considering the Corsair AX760i because truth be told I've become a bit of a Corsair fan since having their cases and fans before.
Yes it is totally overpriced. I'll probably come round to my senses eventually.
But we do have PS4s!
550 easy, 650 to play safe, 750+ if you fancy adding another later. Make sure it has a nice strong 12v line and from a decent make. Be-quiet or Superflower is what I generally recommend.
My system at full load is pulling under 450w from the wall...
Gone for this one, hopefully future GPU's will be using less power not more so this should be plenty.http://www.overclockers.co.uk/showproduct.php?prodid=CA-013-SF&groupid=701&catid=123&subcat=2057
Saw your picture in the Superflower thread. One thing I've just realized is the case I have chosen has a window instead of a 'normal' panel. This is actually really annoying because it's a pretty perfect case for me in terms of size and fan slots. I may have to go with the EVGA PSU instead as the LEDS would ruin it for me sadly (plus 10yr warranty not bad).
Reduce your ambient temp
Or grow some balls and actually twist and pull the card off the PCB.
