If I didnt care about destroying the card, I would try it. As above, I cannot afford to replace it if something happens.
Twist, and pull. TWIST, and pull... gently does it. Sometimes i find it best to hold the pcb and gently peel the end where the pci-e connectors are away from the shroud. Comes off easily then.
