Yep it looks excellent, I don't think the OC version is worth the extra £30 though when you can do it yourself. I'm in two minds whether to get that or 'go crazy' and get a Lightning. I enjoyed overclocking the 780 classified and that would give my overclocking needs plenty to tinker with.
basically, i had the ref 290 running for a good while, the noise is bearable or was, then i put 2 x 280x in the rig and noticed the diff in noise is very noticable, so i figured get shot of my 290 and get a better cooled 290 without the hassle of trying to rip mine apart to get a better cooling solution.
Currently looking at the MSI 290, with the thought of adding a 2nd in a few months.
Just seen i can pickup a Tri-X OC for £290, might just opt for a pair of those
Yes mate the next Civ game is using Mantle. The lead graphics programmer for the game is always singing its praises on twitter. I think it's possible that it will offer some of the biggest performance uplifts on Mantle we've seen yet because it is a cpu limited game typically.
Interview with the Civ team.
http://community.amd.com/community/...og/2014/05/19/firaxis-why-we-went-with-mantle
As simple as that eh? nice...When Mantle is running slow: Profile. Fix my code. When D3D is running slow: Profile. Shrug.
I have two msi 290s and I barely hear them. Keeping two cool is a hassle though and you really need a good bit of space between them. I have to run my 2nd one in te bottom slot of my MB at 4x instead if 16x
I've just got same CPU as you as it was a very cheap bundle. Can you honestly say you have been limited by it for gaming? I only worry about it for Civ V because I recall that being very cpu intensive and I'll be lacking the grunt of the 4770k.
I also have a budget motherboard so not holding out much hope for an OC past 4.2.
Honesty no not that I've noticed yet. I mean yeah there's the odd title like crysis 3 which I know likes 8 cores and I believe BF4 Multiplayer is the same but it's not a game I play. Things like witcher 2 I'm playing maxed except for aa (not needed at 1440p) and super sampling and getting a solid 60. I have civ v but last time I played it was at 1080 with my 7950's but it was still 60fps if memory serves.
Your board is only 1 model below mine and I'm at 4.6 and that was on air. Haven't seen if I can push it anymore with my H100.
