Interesting fact, most of the passengers were sucked out during the blast and were aware of their fate whilst free falling to the ground for multiple minutes, some of them young children.
And you find that interesting ...
And you find that interesting ...![]()
Really. So when Concorde erupted into flames on take off because a small section of rubber ricocheted off the fuel tanks that must have been Hollywood effect.
A supersonic missile detonating next to a fully fuel laden 777 has more than enough potential for destroying the aircraft in one go if not from a fuel explosion but explosive decompression tearing the air frame apart.
You can hear them say Thompson in the recording, regardless of whether you speak the language or not.
Is that what I said.
It depends where it "hits" missiles generally don't actually hit, they explode in close proximity and allow the shrapnel to damage structure/systems.
It in now way must explode like you said so
And since when did the concord explode in mid air anyway? It damaged the engine, set fore and crashed.
Aviation expert on BBC news said that only Ukrainian or Russian military would be trained to operate mobile anti-air vehicles and he's right. Kiev would have known about overhead civ airliners and this is most definitely Russian military operating the weapons.
Has anyone taken responsibility for it yet? Did anyone admit to it?
codeine cures hayfever mate
I'm officially lost.
Its a bit sad that airlines were quite calm about flying planes over this region in order to keep costs down given that planes were being shot down... The idea that 'its OK they're just using the man-packed systems - flying over X0,000 ft is safe' still seems as spectacular an oversight as 'ah its OK we've packaged up the sub prime debt into tranches... its all AAA rated now'.
That only shows that translation is likely to be accurate, it says nothing about whether the recording is genuine.
If it was a restricted airspace then surely it should have been someone responsibility somewhere to direct commercial airplanes to another path. It could not be that easy to go in to a restricted path like that or would we not have loads of airplanes suffering the same fait? I don't see how this could be some kind of accident. Even if the russians thought it was another plane and are shooting at anything in the sky. Why was the plane even allowed to go in that airspace and not other planes?
Not in to regiment you didn't.
