Boeing 777 shot down
Really. So when Concorde erupted into flames on take off because a small section of rubber ricocheted off the fuel tanks that must have been Hollywood effect. :rolleyes:
A supersonic missile detonating next to a fully fuel laden 777 has more than enough potential for destroying the aircraft in one go if not from a fuel explosion but explosive decompression tearing the air frame apart.
:rolleyes:
Is that what I said.
It depends where it "hits" missiles generally don't actually hit, they explode in close proximity and allow the shrapnel to damage structure/systems.
It in no way must explode like you said so :rolleyes:
And since when did the concord explode in mid air anyway? It damaged the engine, set fire and crashed.
:rolleyes:
It in now way must explode like you said so :rolleyes:
And since when did the concord explode in mid air anyway? It damaged the engine, set fore and crashed.
Also, the air is a lot thinner at 30km and fire needs oxygen
Aviation expert on BBC news said that only Ukrainian or Russian military would be trained to operate mobile anti-air vehicles and he's right. Kiev would have known about overhead civ airliners and this is most definitely Russian military operating the weapons.
that isn't the conclusion at all... the BBC had an 'expert' on essentially blaming the rebels
Has anyone taken responsibility for it yet? Did anyone admit to it?
Nobody is going to, this is the hottest of hot potatoes. Even when confronted with evidence it will be denial after denial and claims that the evidence was made up.
And good luck ever getting that black box back from the Russians.
The world is a ***** up place right now (probably has been forever) so much death and destruction all around us :(
Think i'm going to pass on news for the next few weeks, bumming me out everyday seeing the horrors unfold.
If it was a restricted airspace then surely it should have been someone responsibility somewhere to direct commercial airplanes to another path. It could not be that easy to go in to a restricted path like that or would we not have loads of airplanes suffering the same fait? I don't see how this could be some kind of accident. Even if the russians thought it was another plane and are shooting at anything in the sky. Why was the plane even allowed to go in that airspace and not other planes?
Its a bit sad that airlines were quite calm about flying planes over this region in order to keep costs down given that planes were being shot down... The idea that 'its OK they're just using the man-packed systems - flying over X0,000 ft is safe' still seems as spectacular an oversight as 'ah its OK we've packaged up the sub prime debt into tranches... its all AAA rated now'.
Given that blame may prove to be difficult to bring to justice whoever pushed the button and gave such orders, I would imagine that relatives and other organisations are going to put a lot of pressure on Malaysia airlines, other operators on the route and the various air authorities for allowing them to fly through that air space. They will likely seek compensation and charges in court against a company or someone in order to hold at least someone accountable for what has happened.
Other planes had been using that flight path, they have only now banned them!!
Get your facts straight!
