So I've spent this evening soldering together an EDTracker. Computer recognises it, but their software has some issues so I can't flash anything to it with their fancy GUI too, only command line
It's too late and I've breathed in too many solder fumes for me to start with that. So, partway there, but not fully yet.
Still, looking forward to getting it properly set up.
still way cheaper than an alternative!
Can anyone recommend a tracking option for those who can't fabricate things themselves. Only solution I saw was about £150 and for that I'd rather do without
EDtracker can be bought ready assembled for £25 I think? check their website![]()
Whoops, my finger appears to have slipped on the buy button.
Does anybody use a DS4 for this? I've used my DS4 for other games on the PC but was getting myself a bit confused setting up the control bindings last night.
The pad is detected fine, I think I was just a bit tired when doing it yesterdayI don't but I can't see why it couldn't be used to work, what bindings/functions are you having trouble with?
nope, freetracknoir/opentrack is cheaper.
PS3 Eye (120FPS camera)@CEX = £3.50 in store.
If you want to use IR point tracking instead of face tracking.
3 x IR LEDs @auction site = £2.97
resistors @auction site = £0.99
Old wire coat hanger to fashion headphone/cap clip.
USB cable cut off old broken USB device for 5v power.
old floppy disk, remove film disk cut up to use as IR filter.
Someone or several people could make a killing on kickstarter. By creating ED specific joystick, head tracking and other related things. Imagine a logically set out dashboard/joystick/throttle with small displays for ship systems etc.
angerous though, Star Citizen needs exactly the same peripherals. I'm happy as larry with my setup now but it's been expensive and I've had to go to different manufacturers to get the peripherals I thought were best for me (after lots of testing and visiting peoples houses to try theirs out!)The disadvantage of camera based tracking is that it's pretty CPU hungry and usually incurs a fair amount of latency. Latency is reduced by choosing a camera with a high refresh rate (which is why the PS3 camera is good) but at the cost of extra processing cycles. TrackIR deals with that by doing the calculation offboard using dedicated hardware. You can set up FTNoIR to be networked, so use a separate PC to process, but you still have the processing latency and extra latency from the network (though on a LAN this should be minimal). Using LEDs to track will reduce processing power required.nope, freetracknoir/opentrack is cheaper.
Supercruise feels very tunnel vission/auto piloty (if that makes sense) Im not getting the feel of exploring in anyway while doing missions/cargo hauling etc.
I think if in Supercruise there would be some space anomaly, asteroid fields etc, some sort of danger covering a bigger area in the system or something to explore so not always the straight line to the station would be the best way that might would break the monotony of travelin and sometimes.
Perhaps im playing it wrong, but this is my only gripe so far with the game, im sure there will be features released which may change this etc.
I agree about the exploration side it doesn't feel as involving as even Elite: Frontier did
