Best place to buy nic base?
I use this place http://vapersemporium.co.uk/index.php I use the AG nic and AG VG
Have you tried different tanks on it? I've got a couple that it wont fire due to the position of the pin.
when you fire it without connection it reads 9.9ohm. when either of my rba's are on it, it briefly shows the correct resistance (1.6 & 1.9) but quickly shows 'low res'. the device is supposed to be good down to 0.6ohm (with +/- 0.2). i've adjusted the 510 pin on my atties so that there's a massive gap when fully tightened down, but still no dice.
sending it back again and getting a mech, cba with this thing anymore lol
Cheers.
With that being 72mg do I have to do anything to that? Or just use less of it? The one I have now is 54mg from vapeescape
You will use less. You calculator should tell you.
It was only the aerotank and an old I30 tank that had trouble on mine, I replaced the base on the aerotank with one from ebay with a larger pin and it was fine after that.
I still prefer using the MVP2 though, it's taken so many knocks but never skips a beat. If only they'd put the firing button on the side.
Though so, had to double check that
Is AG better? I just use 50/50 PG/VG but I've not been into it that long and on and off often
i've got an mvp2 on order from slowtech so will have to wait for that anyway...
bloody annoying as my vamo is falling to pieces!
I use china post now. My order from Monday is already on it's way here![]()
I find the taste better but that's me. I use 50\50 as well.
http://vapersemporium.co.uk/index.php?id_product=37&controller=product&id_lang=2
http://vapersemporium.co.uk/index.php?id_product=26&controller=product&id_lang=2
http://vapersemporium.co.uk/index.php?id_product=27&controller=product&id_lang=2
I love their TFA Pie Crust Flavour for mixing and it's only £10X100ml.
i used these got a load from them but i swear the strength of the nic is less. Im vaping 20mg juice using this nic but 8 or 12mg usually
Hello me 'ol mucker!
Have a Mirage shop in a town near me. Holy hell that place is exspensiveeeeeee.
