**THE AMD DRIVERS THREAD**
Status
Not open for further replies.
Does anyone know when the latest whql drivers will be available please.
Should be soonish Kaaps, last ones were 14.4 so we're getting near to that three month period.
LT Speculation: 14.7 RC3 will become WHQL and the new 'revamp' drivers with CCC will be the next beta.
OK so I'm using 14.4 for my 290...should I update the drivers ?...I'm asking as here and there since I've started using my 290 I get a drop in fps from about 170 fps to about 30 fps for about two seconds then it goes back up again
Shame they did not do crossfire with 2, 3 and 4 cards then they would have a proper story.
Performance on the 14.xx family of drivers is dramatically better than the 13.xx, it is not even close.
Word and word.
Trying out 14.6 now on Showdown with my 3970X Kaap. A couple of fps behind greg and gee at stock gpu clocks now. :cool:
^^the mantle effect :) Frees up your cpu and your wallet aswell :)
Jokes aside Kaap did me a good deal so i was able to upgrade, coupled with the fact i was able to return my P8Z77 WS and get a full refund so i only had to pay out £60 for the Rampage Extreme. The Dom Plats are being funded from a combination of selling my psu, 2700k and 16gb sammy greens. :)
Really since you like to bench i think it was a good move for you
I should be on a 3930k and rampage formula myself soon. Then all I'll need a is a 2nd cheap tri-x
I'm definitely happy with the upgrade and would recommend it to anyone wanting that little bit extra from the cpu, memory, multi gpu & pci-e lanes etc. Not made too much difference to my performance on Mantle though, such is the power of the API.
Status
