- 2 Jan 2012
- UK.
How many of you guys here will be upgrading to X99?
Did you work out the bclk buttons kimandsally?
Do you know if the older Liquid pro also lasts forever? I've 2 new tubes of that.
I may after a few months when x99 has been established a bit better. Haven't had the 4790k that long, and tbh iv been a bit underwhelmed by haswell and indeed the previous Ivybridge chips due to the thermal issues.
Theyre not a bad chip per se, it's just that they could have been so much better if soldered. I unfortunately believed the hype that they would run cooler than previous haswell chips. The two ive used were worse than my old 4770k. Im currently running at stock, and it's doing pretty ok for games with sli 780's though.Yeah I get you. Been pleased with my 4790K but the other 4770K's I had weren't great for temps.
I think I would be happy with a 5820K / 5960X @ 4.0Ghz, some nice DDR4, and decent Gigabyte Mobo. Z97 is pretty good but was more something to mess with until X99 arrives. I plan on keeping my X99 setup for a few years. By then the mainstream will probably be on 6/8 cores for much less, AMD might even have a 20 core CPU that can't keep up by that point![]()
Just smashed 4 seconds of that previous time by using tighter timings.
My sentiments exactly and will likely buy in a few months if worthwhile.
