Anyone got any more benchmarks? Also, is the X5660 the favored variant of the Xeon?
Really tempted just to go for it.
http://www.xbitlabs.com/articles/cpu/display/core-i7-2600k-990x.html
That may help. Obviously in most tests the 2600k will win (it's 9.6% faster in lightly threaded apps) but once the support is there the 990x wins quite easily.
As our tests showed, the recently launched Core i7-990X Extreme Edition processor with maximally increased clock speed can only compete against Core i7-2600K in a few individual cases – in those few applications that create heavy load that could be well-paralleled.
However you need to remember that the article was written over three years ago, and we now have that support far more than we did back then.
IE - overall when it's all balls to the wall the Xeon will be a faster CPU than the 2600k. I would imagine that's a pretty huge upgrade if you are used to using a 920 or 950.
The Xeon is 32nm, the 9x0 is 45nm. It's a completely different technology.
TBH the only reason the Xeons fell short of Sandybridge on overall perfomance was that they don't overclock anywhere near as far. Sandy 2600ks mostly did 5ghz (or less once people realised it was a bad idea to shove them full of volts) whereas the Xeons need to be really well binned to reach 4.5ghz on water.
Either way the Xeon (or 980/990X) is a formidable upgrade from a quad core I7 on X58.
but they're both great CPU's and compare very well to the 4770k @ 4.4Ghz.
Yeah TBH I would say that 100% utilised that's about a very fair assumption. BTW as promised.. Here is my 3970x @ 4.7ghz.
So I'm only around what? 15% higher than your results. I can push on to 4.8ghz but then I run close to the edge...
Cine is one of the best apps for testing a CPU's overall might.
