now that is quick.
EDIT,
2666MHz CAS9!!!!![]()
nice stulid
your starting to loose dram efficency though.
can you post up a IBT 5 pass showing your temps with those settings + a GTL 2.0 screen & memtweak open showing your voltages. also with aida open showing your correct voltage load so i can compare
Impressive stupid, this kit seems to keep on giving, nice low voltage on it too.
Ahh, i seen earlier you were putting 1.67 ono into it.
stud i see your memtweakit score up top for dram efficiency and it is low
with my memory if it was clocked at what yours was it should be higher
my current efficiency is 41804 @ 1200mhz *2400* speeds.
it could be that your getting massive error correction, or it could be the massive dram refresh interval your using.
I wouldn't pay too much attention to the efficiency score memtweak reports.
Iv'e looked deep through the RAM addict page at OCN and it seems that the score varies widely between different speeds and ic's used.
Same for the SuperpI thread at HWbot, there are scores there that are really low but the SuperPI times are incredible.
Example,
Samsung - http://i.imgur.com/UjMTiVa.png
Hynix MFR - http://i.imgur.com/1rhAnts.png
i have always ran my memory @ 1.65v.
can you post a picture of your GTL 2.0 so i can see what IO/AO/DRAM voltage you are using.
