thanks, just sanity checking. not a problem if youve got one lying around, but a bit of an oversight when you have to have the screen connected to PC for those ports to work, and if you want to do a hardware calibration as well
yes they do normally. It's just that it's odd that LG don't provide the cable in the box to connect the PC to screen so you can use that feature! (and use the USB hub ports)
Are you loading an all black image or a webpage or something? I can try replicate but havign used black images before on this screen (both even) I can confirm no backlight shutoff!
I take it in your OSD that Calibration is "on" which automatically disables the Super Energy Saving function? (Function tab in the OSD).
Could it be that they were advertising it quite a bit for Macs? Since with just Thunderbolt I never needed the USB to connect to the display to use the USB hub or for calibration.
I get that on the 34" UM65 even watching bluray discs if it has a black screen whilst loading the LG shuts off its very fast at coming back but not sure how to disable as its obviously to save lamp bulb life!Yep theres a 1:1 scaling option in the first section of the OSD which should do the trick. Not sure why youd want to though.
Just noticed something weird while testing with an all black screen. After 5 seconds the backlight gets shuts off. Like some DCR functions do, but as far as I can tell there's no DCR function to turn on or off in the OSD? There's no sign of any other dynamic backlight control during any uses, just this backlight switch off on an all black screen. Maybe a hang over from a DCR function they removed at a late stage?!
Set your Nvidia control panel to GPU scaling & maintain aspect ratio should sort that if the LG is set to 1:1.Wait... the 1:1 thing doesn't work. When I launch a game it stretches across the whole screen, even when resolution in-game is set to 1920x1440. And when disable "full screen" it goes into windowed
I need this because my GTX 780 ti can't cope with some newer games at full res (very disappointing TBH). So rather than sacrificing detail I wish to play with a lower resolution, but not stretched.
That explains it then as Blurays force 23/24Mhz mode to maintain sync with the film FPS.None of that here, if the refresh rate changes the screen will shut off and restart after about 5 seconds as the display reboots. A good way to tell this is have the led for power set to off because if the monitor restarts the led will come back on while it is booting and revert to off once booted.
I get frame skipping with any of the vsync options in MPC on GTX780Ti + Core i7 980X 12 threads XE CPUI use MPC-BE for all my MKV files, I have a few in 4K and the rest all 1080P/720P. If a film stutters (rare, can't recall the last time it happened) on slow scenes I enable the advanced vsync mode in MPC, seems to sort it. I notice no frameskips in the MPC-BE playback stats view though.
