seems to of fixed my temp issues![]()
I flashed to it about an hour ago as I'm having some shut down reboot issues which has me completely baffled, but my temps are reading a lot lower. at 1.185-1.2v large FFT under prime I'm maxing out at 50c @ 4.3
You aren't getting code 53 by any chance on reboot
I've never managed to check the board to see the code before shut down and reboot but no it's not hanging on 53, it literally just powers back on as if nothing has happened. 53 is a memory training code.
Since flashing...
Nah I dare say it
Deluxe and 5960x ordered , still need to sort memory tho, seems all the good stuff is in short supply![]()
What memory are you getting?
Any idea whats the difference between X99-S and X99-Deluxe? They are exactly the same in terms of specifications and design but the X99-S is a lot cheaper (around £100). It's available on ****, Amazon UK as standalone product and on OCUK, it's part of a combo here: http://www.overclockers.co.uk/showproduct.php?prodid=BU-023-AS
Hassanain Saeed Looking forward to a new Rampage V block from you
Like · Reply · 5 September at 19:37
EK Water Blocks It's in the works, hold tight!
Like · 1 · 6 September at 00:53
Milko Tsanzov Do you plan to make monoblock for ASUS X99 Deluxe?
Like · 6 September at 08:14
EK Water Blocks Milko, unfortunately not, because of the PCB layout it is not possible (battery).
Like · 6 September at 10:24
Milko Tsanzov OK. I'll buy the Extreme then.
Like · 1 · 6 September at 11:09
