- 6 Jan 2013
- Rollergirl
Ignore, I sussed it.
So here's a weird bug I ran into playing earlier...
I was riding down the road on Frost, my trusty steed, when I catch sight of another horse by the side of the road out of the corner of my eye... As I get closer I realise something weird
The other horse looks exactly like Frost! It's in a spot where I'm sure I fought a dragon earlier in the game. I dismount and take a look
"Frost" doesn't come up as the name of the horse, just "Horse", and when I look in its inventory I find - a carbon copy of what the "real" Frost has!!
I'm going to ignore it, as I don't really need the extra items or whatever, but has anyone else come across this?
Thanks guys. I've tried the first two (don't know how to do the third) - with no effect so am trying a fresh install.
Archive invalidation?
The .ini files are in \My Documents\My Games\Skyrim.
You can just rename or move them, then the next time Skyrim loads it will create new default .ini files. If the default ones don't help, you can delete them and put your old ones back.
It didn't do anything sadly, but thank anyway.
I deleted all local content via Steam and reinstalled from the disk. With all mods/plugins disabled the game reloads a savegame and the graphical problem is exactly the same.
Verifying the cache says 1 file needs to be redownloaded but then nothing happens.![]()
Mods I add to Skyrim aren't working in game. I've tried adding them with Nexus and the Steam Workshop. The sync when I open the game launcher though
Anybody know whats up?
What mods?
Don't use steam workshop.
Probably load order conflicts among other things.
Get Mod Organiser (or NMM if you're happier with a less sophisticated mod manager) and LOOT - download and install everything through Mod Organiser, let LOOT set the load order.
Thanks a lot, it works with Mod Organizer![]()
