- 22 May 2012
- Manchester
Just got into the Outland and I'm level 58. I'm on Magtheridon if anyone wants to do some dungeons?
It wont be.
Remember about the proc, even if its tuned down accordingly.
This was a major upgrade for everyone and good dps/hps boost.
My question is, what about legendary meta gems for helmets.
Are they going to fit into WoD gear etc![]()
I would miss that haste proc...
It wont be.
I've only done the gem part of the quest line for the cloak, is it still reasonably easy to get the cloak? I quit a few months after release if it makes any difference.
Re-subbed and playing Enhancement Shaman. Enjoying playing again but forgot how boring it is to run around everywhere, roll on my mount. Playing on Chamber of Aspects (Horde) if anyone else is on there.
Why stay subscribed if you are no longer enjoying it? You've got just over 2 months until WOD hits.
Already cancelled mate, got 10 days remaining on it. I did a pug raid of SoO normal the other night and quite enjoyed it, plus got some loot. Think my priest is in a decent enough position now for WOD leveling so pretty much done.
When you move the cursor over an item in your bags and have the char screen open should it compare the 2? I'm sure it used to or am I just dreaming?
Hold shift or alt. One of the two keys should compare the two!
I think the XP for leveling may get changed a bit, seems really quick atm.
I thought that they said they want levelling to be fairly quick so they can focus on end game.
Maybe you're right, I just assumed it would get increased.
