The Asus X99 Deluxe Owners Thread
I flashed to it about an hour ago as I'm having some shut down reboot issues which has me completely baffled, but my temps are reading a lot lower. at 1.185-1.2v large FFT under prime I'm maxing out at 50c @ 4.3
You aren't getting code 53 by any chance on reboot
Deluxe and 5960x ordered , still need to sort memory tho, seems all the good stuff is in short supply :(
The only review we need :)
Edit : Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit (CMD16GX4M4A2800C16) ordered , hope its gona be ok
I've never managed to check the board to see the code before shut down and reboot but no it's not hanging on 53, it literally just powers back on as if nothing has happened. 53 is a memory training code.
Since flashing...
Nah I dare say it
Since flashing...
Nah I dare say it
I was getting 53 for some reason but it's cleared now
What memory are you getting?
Would love the best(fastest) but it depends on funds and what i can get/what they got in stock, dont want to wait too long tho so maybe just the cheapest (Crucial 16GB (4x4GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K4G4DFS8213) to start then upgrade it later, will post results when its up and running ,
Just in case anyone was thinking of watercooling the deluxe, taken from FB page
Hassanain Saeed Looking forward to a new Rampage V block from you
Like · Reply · 5 September at 19:37
EK Water Blocks It's in the works, hold tight!
Like · 1 · 6 September at 00:53
Milko Tsanzov Do you plan to make monoblock for ASUS X99 Deluxe?
Like · 6 September at 08:14
EK Water Blocks Milko, unfortunately not, because of the PCB layout it is not possible (battery).
Like · 6 September at 10:24
Milko Tsanzov OK. I'll buy the Extreme then.
Like · 1 · 6 September at 11:09
Well im up and running (deluxe + 5960x + 16 gig dom plat) @ 4.3 temps are ok while its doing nothing (30c) but running seti! ouch, 80`s , hitting TJ max and slowing down, somethings not right but not had time to find out what. yet
wish me luck
edit: water temp is only 37c coming out of block so maybe i need to check the tim, will try ic diamond tonight
edit: just sorted the temps with a bios update 41/56c now under full load , phew
omg i just ran 5 way and the cpu went over 10MHz with no sign of stopping , until i clicked stop and it then carried on and ended up at 3.7 :( , well weird, i have on video and pics. temps were low, must be a bug eh lol, ill try again
thats 8250.0 and rising!
edit: seems to happen when i enable the EZ XMP switch and CPU over voltage jumper (both off by default) page 1-20 in user guide
all seems ok with these disabled and i get 4.4/4.5
bios X99-DELUXE BIOS 0801
