Caporegime
- 9 Mar 2006
- Surrey
Yeah I'm doing that one now I've reached vanguard 3.
Yes for Vanguard. I assume crucible too
Frustratingly accurate:
In fact, I've done 45 or so strikes and not 1 boss has dropped even a green. So, do bosses EVER drop things in Destiny?
Or is it always just a random chance after the timer?
I feel it's not about how hard the enemies are (i.e. end boss) but more about the hordes and counts. i.e. Doing the moon mission outside the temple, killing only Tralls, I get loads of drops because I headshot and multi-kills with Fusion Rifle.
Killing the end boss, nada.
I was wondering about the headshots/crits/multi-kills etc earlier and whether or not it affects the drop rate.
I grinded that area yesterday for a few hours while blasting some heavy metal to keep my motivation levels up. Don't listen to the genre much these days but man it suits mowing down enemies on Destiny!!
It 'felt' like I got more drops when I was more accurate and got more headshot kills quickly but I couldn't be sure as sometimes nothing popped up. But yeah an hour or so gets so about 30 drops, typically around 10 Blues and maybe a purple or two if you're lucky. The greens are just the standard drops from Thralls so always the same gloves/leggings etc.
Should hopefully be picking this up tonight, just a quick question..... how does single player work? I've read there isn't really a single player and you have to always be connected, is this true. Or can I play solo and level up the same character as when I'm with friends?
Only reason I'm asking for solo play is that the times I mostly play games, friends are working and when they're not, I'm working.... until weekends.
ah right, so weather alone or with friends it's just the same character? not one for each.
