91? That's about what I get on sli 780's, 1920x1200 x4 msas and full ultra settings.
Then something is wrong with your system.
I thought so too, but apparently, once they are overclocked this much, they will hit the power limit and downclock themself.it only throttles if it overheats? far as im aware
only way around that is to flash an unlocked bios (I think)
650 Watts psu it enough for 2 cards? OcUK staff told me yes)
Yeah that's the point I was making, a slim 120mm aluminium rad can just about cool a card that puts out almost double the heat of SLI 970's, so for SLI 970's the rad space needed from regular thickness copper/brass rads would be minimal and extra rad space would allow the fans to be turned way down
I am going to be replacing a single over clocked GTX780 with SLI 970's and don't expect it to affect loop temps much at all.
Those who have a card, does the card throttle during long game/bench sessions? I have read elsewhere, that those boost clocks are misleading, cause the power limit on the cards will kick in and reduce the boost.
Isn't it something to do with when your PC is idle/not under much stress the clock will automatically lower itself for less power consumption? It's the same with processors as well; if my PC is idle then my cpu will run at something like 1.3ghz
That's normal rob77, if you go to the sensors tab on GPU-Z and set it to read the max reading for core, run a game then check it, it will report the full boost clock.
I know that, but that is not what I am asking. I wanna know if the cards will throttle once overclocked to say, 1500mhz boost, if for example, they will start at 1500mhz, but over time, drop to ex. 1400mhz.The power limit is the current limit to how far people can take there cards. But as the amount of power you draw will remain roughly constant throughout a gaming sessions, unlike temperature which will rise as the air in your case rises.
For kepler cards the solution was to flash an unlocked bios (skyn3t's was great as it had huge power limits and no GPU boost so the overclock was 100% controlled by you) but at the moment there is no way of flashing Maxwell cards. But I can almost certainly say there will be a method shortly.
I've seen it happen on my top 780 a few times when benching, boost speed of 1202, (stock of 1124). Even on 100% fan speed the temps hit 74c, boost will drop sometimes. Does changing the temp target not help to eliminate this?
