Hmmmm!
Just tried running IBT and temps into the 80s in no time at all. Seems 4.7 isn't such a good idea after all !! I think I will try 4.5 instead.
Ah OK thanks for the advice, you think its OK even at 1.4v + ?
80 on water just feels so wrong![]()
if anyone is running 12 gb ram on x58 can they post their bios settings please?
Have you try a different combination? you have 6 slots and 6 ram sticks, maybe if you swap them around.if anyone is running 12 gb ram on x58 can they post their bios settings please?
Heres mine ... http://forums.overclockers.co.uk/showpost.php?p=26833506&postcount=207
Running 6 x 2GB 1333MHz. I'm now at 22xx205 = 4500MHz which overclocks the memory to 1638MHz but thats by the by.
