Just had a little delivery from DPD, great service from OCUK
Let us know what you think of it, this if my first choice, just waiting
for some stock to arrive
So Tri-SLI a waste of time on an i5 2500K Socket 1155 ? (EVGA Z68 FTW) PCIE 2.0
How about if a BIOS update would allow me to use ivybridge CPU + PCIE 3![]()
Got mine at 1416Mhz Core Clock and 4000Mhz Memory, temps max at 61C and can't even here the fans
Played 64 man BF4 on the Pearl Market map:
GTX680 (Overclocked)
Frames Time (ms) Min Max Avg
127225 1608359 40 120 79.102
GTX970 (Overclocked)
96350 1168094 46 128 82.485
Not really impressed with just a 3fps increase on average tbh. Maybe it's because BF4 is more CPU dependant.
The only reason you would swap a 780Ti for a 970/980 is for the energy efficiency and new tech. If you have money to burn great, but you wont see much of a performance boost.
Then again, it might lop off a decent amount off your energy bills if you game a lot.
for some stock to arrive![]()
SNIP
Yeah on this review they got ~45% increase on BF4, so something doesn't seem right there.
It looks like a very well made card, the heat tubes are huge! I went for the ASUS as I liked the new power supply design and fan technology.
I will get her installed tomorrow and post some benchmarks![]()
Maybe you should just leave them stock, it's pretty simple:
With afterburner installed and no settings messed with it won't allow you to increase voltage anyway, so less likely to burn your card, not that +87mv would do that anyway as it seems it only really adds +32mv.
For a starting point try 110% power, +100 on the core and memory at +500mhz, most Samsung ram on these cards seems to be able to handle it fine.
Put the fan to 100% and run a benchmark such as firestrike or heaven. You can leave the fan at auto if you want, I just always max it for benchmarking.
If it works increase the core in 20mhz stages until it crashes or artifacts. Then lower it to the previous value that worked.
Do all this and then if you want extra from overvolting ask how to do that.
That was SP and the FOV is set to 70, I have it at 90. I think it's the game, gonna run Firestrike benchmark now just to make sure.
FireStrike score: 9921
Link: http://www.3dmark.com/3dm/4145550
Does that seem right to you guys?
It's reporting my CPU at 2.6Ghz even though it's overclocked to 4Ghz. CPU-Z shows it at 4Ghz too.
Just sent my cards back, hopefully I can get a full refund then look at getting some different ones.
Seems about right.
