anyone gone the ITX route with a small case & compact cooler?
http://www.overclockers.co.uk/showproduct.php?prodid=MB-630-AS&groupid=701&catid=5&subcat=2811
Spent a couple of hours reading this thread after getting the 'upgrade' itch (from a 2600k) and atm I can't see it being worthwhile.
Has anyone else gone from 2600k to 4790K?
ya, from 2700k.
those Sandy were such a FiNE SeXY Chips (sold main).
the oc, the stability, the temps, need for heatsink.... everything about those sandy is pinching my hart now.
Is there a decent difference from sandy to the 4790K? Was it worth it in your opion? cheers.
no.
no decent difference.
no, it was not worth it.
after i said that......
in my opinion, or through my eyes, it seems that as the Tech getting smaller and faster, the heat is not going down.
iv got the ASUS 780Ti and boy this one is hot. we already see the hybrid gpus (and we know there are more to come).
if i could take what i know today and go back a year......i would have stayed with 2700k and gtx680.... and just waited for the (Volta) pascal and skylake. so all the lessons that needs to be learned from the new DDR4 + X99 + Maxwell.. would be learned and fixed.
New build with 4790k and wondering if these temps are norm. Everything is set at stock/auto. I'm using a gigabyte z97x-ud3h mobo with latest bios (f7) w/ evo 212 cooler. Idle is around ~30c and load upper 60's. Playing BF4 last night and saw a peak of 67c. In CS:GO I saw a peak of 66c. Vcore in bios is 1.269 I believe.
That's a shame about your 780Ti, i've got the Evga 780Ti SC with standard cooler, it runs fine and i never hear the fan kick up.
I was thinking the same about either Broadwell (if it comes to 1150) or wait it out for Skylake.
for now it seems i'll just have to ignore the itch!
Make sure that you have the latest bios for your mobo, so that vcore isn't being set too high. 67c in games seems a wee bit high, not dangerous by any means though. I'm seeing mid 60's at 4.7 in games, though I do have a much larger cooler, cpu at 4.7ghz on 1.3v
Are you running the latest bios for your board? A lot of early versions would set pretty high vcore and a higher 4400mhz cache/uncore clock. Running real bench results in a max temp of 81c for mine, 4.7ghz on 1.300v. Air cooled with a k2 and dual 2350rpm corsair sp PWM fans.
