That's really good to know, cheers.
How would a cooler fit on the CPU? Would it (h100i) fit or would I need to get another cooler?
I'm thinking that I could get a xenon chip, mobo and some 1600 ram to keep me going a year or so until I save up enough to buy a new motherboard bundle outright...like the £700 x99 setup in the shop just now.
Everything else I have is in my sig and I'm thinking I don't need to buy anything more? I guess it's all about the motherboard right? Get the right board, decent chip and ram and I'm off. I'd be looking to get the hexcore to 4.0 which would suit me fine for gaming and general useIs this doable?
Find the board first and then work from there. The chips are abundant![]()
1366 or x58 board is what you want. Though tbh getting a x chip if you already have a system is a good value upgrade. Spending money on a chip and board will increase the cost to a point where you might as well get newer stuff.
Does anyone else's overclock need two or three reboots when you turn the machine on? Mines running at 4.0Ghz on the Gigabyte UD5 but for some reason, it seems to restart itself a couple of times at boot. Once it's in windows it's fine.
I'm running 6 sticks of memory if that's maybe the issue.
Yeah I guess you might have a point. Although getting a good modern setup for £200 would be very hard unless I was again going down the route of a second hand setup so it might be a much of a muchness.
