Those are still amazing over clocks though!
Yeah extremely happy with the performance of the card. Never went above 63 degrees either on a custom fan curve.
Trying to reduce fan speeds to give the card extra power next.
Top card sits at 80c under load bottom card around 65
If it's a good PSU is totally fine. I don't go over 400w (from the wall).Only a 750 Watt PSU? Though you needed 850 minimum for SLI
Anybody with fan issues on MSI cards?
Get onto who you bought it from and have it replaced?![]()
I only noticed it started happening yesterday (I think). There are other reports of it happening, so I thought I would give it a day or two to see what it turned out to be.
Here are mine, msi gtx 970 sli
** If images are wider than 1280 pixels please either use links or spoilers **
Ugh this fan issue is annoying. Which card was it other than the MSI that was also having problems?
Do the Gigabyte 970's fans only start when it reaches 60c like the MSI or is it a different system?
Thanks
no they dont only the MSI and Asus have the 0db function
