most of the mods.
Mod Organiser.
Fresh install.
I've used your guide all the way to the point where I am ready to install ENB. I have been testing, and in a busy spot in Markarth I've dropped to 39 FPS. See screen shot (it's a 6MB file so might take a minute to load).
I'm using a GTX670 SLI setup, and my cards are hitting 1782MB of memory usage at that point, and maxing out the 2GB at others.
I've installed all mods to this point, so what would you recommend I do to improve performance before proceeding with ENB?
http://i.imgur.com/YP0ad5S.png
Have you got TAVE - Markarth installed? - Try removing that and checking the performance as that will be loading a lot more items into the city. Also, expect your GPU VRAM to be 90%+ with all the mods installed as there are a lot of textures being rendered and loaded.
Nvidia Inspector is a great tool to make sure you have the right settings for Skyrim, download and check the Skyrim preset then apply them. (make's sense when you see the tool).
** Update **
Nvidia Inspector... Wow! What a difference. FPS only dipping to 55 at that point now, and sitting at 60 most other places.
How does NI work? Do I have to go to each game, apply the settings and then I can close NI and those settings will always be there? Are my Skyrim presets only applied to Skyrim?
Cheers BTW.
Dumb question but do I need to do anything special with an already working ENB when upgrading graphics card?
Anyone know how to get RadeonPro to work with Skyrim + ENB + Mod Organizer? If I run it normally or by adding it as an executable in MO it still doesn't seem to work.
I get micro stutter and want try and cure with RP but my settings dont seem to actually get applied.
I've added real vision enb, and performance is fine but I actually think it makes the game look worse. I really don't see what the fuss is about!
MO uses a separate directory to keep the default one tidy and vanilla.
You can't use a seperate tool to launch MO to then launch the game.
Have you applied the 64hz stutter patch?
I'm not, i'm using MO to RadeonPro (as you would with LOOT or TESS5Edit) and then MO to launce SKSE as normal. I'll have a look at the stutter patch.
@ ReaperGuy Here's the screenshots. It's a Dropbox link as I kept the full image size.
https://www.dropbox.com/sh/79ppr7or7ynlla8/AAAYbGwgOc5QmdQuPH-A1F3Aa?dl=0
In my opinion...
- Riften is all fuzzy
- Inside Bleakfalls Barrow is so dark I can hardly see where I'm going
- When it's snowing it looks, just, not right... like there's too much snow or something
Doesn't look right, any screenshots when the sun is at full, are they similar to mine around Riverwood & Whiterun?
Is DOF working?
Shadow's look OK, darkness can be altered if you press SHIFT + ENTER, I prefer it being so dark but can be changed.
Look for the interior shadow setting and adjust that.
To me it doesn't look like the ENB is even on.
When you start the game you get the ENB messages top left of screen?
