Updated my 250GB evo just now. Never noticed a problem before if im honest mind.
amount of data writes that's require to implement this fix....This is what I and a few others have been saying, yet some have sold or returned their EVOs in order to get a "better" SSD. Their choice, I suppose. If this update turns out to not fix the problem properly, then it may have been a wise decision, otherwise it would appear to have been a bit hasty, and possibly more trouble than it was worth.
Is this confirmed or is this peoples assumptions? Everyone keeps coming up with their own summaries…. All I keep reading is peoples own views on what they think is happening.
And for those worried about the "massive"amount of data writes that's require to implement this fix....
http://ssdendurancetest.com/ssd-endurance-test-report/Samsung-840-EVO-120
It's not entirely clear if the 78.47 TiB written was as far as the SSD under test got before failing, but if it did fail at that point, it means that writing 100-200 (ish) GB to "refresh" an EVO after the firmware update isn't going to make any significant difference to it's lifespan. Yes, there's a principal involved, but it's not really worth mentioning IMHO.
Applied the update, seems a tad slow?
Would be expecting 400mb+ usually
Mm, my SSD has "latest firmware" even though I haven't updated it? Problems? Currently on "EXT0BB6Q"
No one seems to have an answer to 'will it work on a raid' I have 2 250gb Evos in raid0. Who with a raid setup is going to test first.
If no answer by tomorrow I'll go for it.
You need to update.
EXT0BB6Q
to
EXT0CB6Q
Just tried. Cannot find Evo drive. Seems it doesn't work with raid!
