- 4 Oct 2008
- London
quick question, if I flash it the Google way can I just flash SU afterwards and have my super user?
. So your free to buy all devices.
My SD card is totally wiped and no app can write too it, anyone else getting this issue?
I had a similar sounding issue when I first loaded the original L preview. It was as if my memory was blank, but if I restored back to 4.4.4, everything was back to normal. I reflashed a few times but still the same.
In the end, I copied everything on the 'SD Card' to my PC, flashed the 'userdata.img' which wiped everything, then copied it all back again. It worked perfectly after that (so did 4.4.4 when I reverted back too) and also the latest preview works great.
That's interesting, I presume the initial unlock on boot is longer than usual ones as it decrypts?I just updated to this new Developer Preview and then encrypted the phone... It didn't ask for a password.
Now the phone is encrypted but with no password, is this normal?
Edit
Seems it is, removes the password entry on boot which is decent and you can use any form of password entry to get into the phone.![]()
