Don
- 20 Oct 2002
- In a house
Looks good. How did you power it off the lights circuit? Is that possible with the 0801?
My mirror's not powered but the windscreen wiper rain sensor is already behind the rear view mirror and that obviously has a power supply that's only on when the ignition is on. Would be much easier and tidier than running it down pillars and into the cig lighter!
I just spliced into the light circuit, it's only live when the car is active (being driven) unlocked, and keys are within proximity.
It works out quite well. The only problem seems to be, if I power on more than 1 interior light, the camera goes into shutdown mode.
There are a shed load of lives in that ceiling area though, so I will try another to see if it will allow a bit more current draw. If that fails, I will just pull up a small gauge cable up through the trim panels from the cigarette lighter live. I am fairly sure there is a cable for a power sunroof (my car has no sunroof) so will have a dig around with the multimeter and see what I can find.
However, since I never use the lights when I am driving, its not a major issue for now, and so much more tidy.
In regards to the 801, I don't see why not. I am considering running a rear facing 801 as the next little project. If I do that, I might stick in a direct battery cable (its in the boot) with a relay running off the interior lighting just for the rear
I could actually do the same for the front mounted camera, there is a shed load of room in the roof panels!
