Just sit closer to the screen at the cinema
While no, you can't use VLC, there is a "VR Player" that lets you play standard videos as well as 360 and 3D ones.
You can choose how far away the video appears etc so you can have it a distance that suits you.
I wish they allowed it in trackir as well, because you can do the same essentially :/
The syntax is documented at http://www.eurotrucksimulator2.com/input_config.php#input_configuration. The only change since that definition is addition of helper function clamp(x,y,z) which is equivalent to min(max(x,y),z). To remove the limitation you need to change the lines defining headtrx, headtry and headtrz which use this helper function to limit the input from TrackIR into a box.
What's it like to watch movies on?
Does it give you that immersion feeling, or is it like being sat an inch away from a TV?
In my head it would be like having a 100+" screen, but after speaking to someone else they say it would be rubbish for movies..
If you position the screen close to you it will be very uncomfortable to watch, pretty much exactly like sitting an inch away from the TV!
Anyone else struggle to use theirs?
I last 10 minutes until motion sickness sets in.
Of course, if you're too close it will be uncomfortable but as with everything - move further away.
The DK2 is absolutely mental to watch movies on, it literally is your own IMAX, except of course you're currently watching a VHS tape on it.
Looks like you can change this if you wish.
https://developer.oculusvr.com/forums/viewtopic.php?f=42&t=2378&start=60#p65764
That's for position, but it's probably possible to edit the rotation limits there too.
If you view it in some sort of 'cinema mode' with borders etc. Does it feel like your watching on a massive screen though?
I really need to try one, or bite the bullet and get one. So intrigued.
You're not alone. Although, as already mentioned, it depends on what you're playing.
Any game that has a cockpit is great to play. On the other hand, I can't last 5 minutes playing, Alien Isolation -- which is a shame as it looks amazing in the rift.
I really need to try one, or bite the bullet and get one. So intrigued. 100% will be buying the consumer version.
I have this problem with any game that allows me to walk around -- regardless of whether I can maintain 75 FPS or not.
hmmm, got mine today and Im a bit dissapointed.
Im not really getting any of the immersion I was hoping for.
