BTW masterOC, did you get a good overclock without frame skipping?
Very strange that, contact LG and let them know, they might be able to explain it.
Are you able to try a different GPU out?
PS, might want to re-edit the video/"beep" out the swear word before an ocuk don watches the video
Thanks! I will try OC mine later on and report back.
ill pull it and do a decent vid today hahaDid you use nvidia control panel to overclock the monitor?
EDIT:
By any chance, could your issue be down to the 70Hz overclock?
Most of us have the brightness less than 10. Mine is 8 for example. IPS glow would normally disappear if you look at it straight at it.
Where did you get yours? Is it simply a USB powered one? I was concerned they may be a bit on the bright side.Nexus18 said:I recommend getting a white LED strip for the back of the monitor, gives the perception of better blacks/contrast ratio and thus makes bleed/glow not as obvious.
