The back of my case where the card sits is getting very hot for some reason, it's nearly too hot to touch. GPU temps are normally in the high 60's/low 70's when I'm gaming, so I can't see why it heats up so much.
My 660 operated at around the same temps and that never pumped this much heat out and the cards only have a 5 watt difference.
It actually makes any cables plugged into it go limp, they get that hot. Can't be doing them any good.
VRM?
