Latest update on the member list and war participation sheet http://bit.ly/ZHWuv3
54 attacks last war which is one of our lowest turnouts ever, however it was against a very tough opponent.
Ahh I see, was hoping you could attack your friends xD.
Lol, you sure they are your friends
. I'm not sure you understood, but I normally play those MMO's that have similar systems, make an alt and attack myself to boost my exp/gold.I'd like to play this game, but it doesnt like my jailbroken device - it just hangs on the initial screen.. Any workaround for this?
Ahh I see, was hoping you could attack your friends xD. And yeah the game really seems to centre around Gems for any real progression, guess I'll just grind it out for awhile then join you guys. It does seem like hmm fun I guess haha.
I suggest you try again! Usually mine only hangs on the initial screen at work, it doesnt seem to like the wifi or its restricted. All i do is turn off wifi whilst im at work and all is ok![]()
That's strange. I'm using mine on a jailbroke iPhone 6 and have no problems. You tried jail breaking or downloading application again?
When I switch off Wifi it complains about not being able to connect to server.. It hangs on the initial Loading screen.
OK I think the problem is down to Wifi.. I tried the game on a 3G iPad and it initially hung on the first loading screen.. However when I disabled the Wifi and left it on 3G only it worked.. Strange, or what?![]()
. Any advice? I'm guessing I need to take a few wall bakers, use the giant dude and small warriors as tanks and drop some archer behind them.
