- 10 Mar 2009
- Newark
Looking good! What did you use for the headlights? I've heard toothpaste is good... mine need doing at some stage. Getting some condensation in one of them too, a new one is extortionate so need to investigate sealing it somehow.
At £30k a Civic Type R sounds expensive, even if it is a beast. I suppose this is the going rate for a hot hatch these days. Are they releasing a warm version too?
I gave them a sand down with some meguires 2500 grit wet and dry paper using water and fairy liquid, upon drying you will think you have ruined your headlights as they will be really dull and even more cloudy looking, i then used some meguires scratch X 2.0 to buff them back up and they now look brand new, takes around 15minutes per light!
