The smoothness line doesn't exist in my XML file! I hab mouse acceleration off in settings yet it's still laggy though.
3770k 4.5GHz, 16GB 2100MHz, GTX980 Gaming.
I get 60fps for the most part - but do get some drops to 45 on Ultra (1080p)
4770k, 8gb, gtx980 gaming
Should be using "Nvidia" Preset on a 980!![]()
i heard it makes performance worse
I notice when using the bow there is no target reticule or am i missing something ?
anyone else getting random "farcry 4 has stopped working" issues? patched but still doing it.![]()
[Post FX is] .. used in combat and cutscenes, these settings aren't to everyone's taste, and if that's the case simply turn them down. You'll get an improved framerate when it's all kicking off in combat, and you might find it easier to see, aim, and shoot, too.
Under the hood, the Dunia 2 engine requires at least 1GB of video memory (VRAM) to run at minimum settings according to the official system requirements. In our testing, however, we saw the lowest texture setting using 2GB of VRAM. Curious, we measured the amount of VRAM used at 1920x1080 at each detail level, with max settings and SMAA enabled, after a 5 minute fixed path drive taking in several of Kyrat's sights:
The use of additional VRAM in our tests is likely a modicum of texture caching, intended to accelerate the rendering of textures in the scene you're approaching, preventing stuttering while the necessary items are loaded from your hard drive into memory. If you've got a GPU with no additional headroom, such as the recommended GeForce GTX 680, it'd be wise to load Far Cry 4 onto a SSD to minimize the delay between the game requesting a texture and it being loaded. On a slow mechanical hard drive, there could certainly be stuttering that detracts from your experience.
