- 17 Aug 2012
- Tamworth, UK
That looks vanilla mate, what happened?
That looks vanilla mate, what happened?![]()
Press F12 for a screenshot, the Steam overlay needs to be active for it to work though iirc.
I went back to a level 20 something save recently to test a mod and I couldn't bear it, bandits killing me with a few shots... even managed to get killed by a bear. The shame.
"player.forceav carryweight xxxx" example = player.forceav carryweight 5000. I can confirm this one works, I also tried two other codes for this previously which were "player.setav carryweight x" and "player.modav carryweight", they both worked in-game but once you quit out and logged back in they no longer worked, so "player.forceav carryweight xxxx" is the only code that actually works and sticks.
ok so I have figured out how to get 3440x1440 to stick but it still doesn't use the full wides screen 21:9, has thick black bars either side. this is with using the enb btw.
Well that's just effectively disabling the concept of having a carry weight at all...
Depends what value you use...
2 best things for bag space:
1. Convenient horses mod - you can keep tons of stuff on your horse (once you get one)
2. Bandoliers mod - you can craft bags + bandoliers which you wear and they increase how much you can carry
From the OP...
( (To open the console press the button to the left of number 1 on your keyboard, press it again to close) ) - Tilde Key"player.forceav carryweight xxxx" example = player.forceav carryweight 5000. I can confirm this one works, I also tried two other codes for this previously which were "player.setav carryweight x" and "player.modav carryweight", they both worked in-game but once you quit out and logged back in they no longer worked, so "player.forceav carryweight xxxx" is the only code that actually works and sticks.
Crafting Overhaul changes the weights of a lot of items, I find I can carry much much more, I believe it also adds craft-able backpacks which you followers can wear as well. (One of my mods does).
You can see them on your back as well.
Did read this morning though, not checked if it still works. If you drop things on the ground (or place in a chest, but this would make the item be considered stolen) and tell the Follower to pick it up they will even if they are overloaded and they can still move about as normal.. Might been changed in one of the mods though. *shruggs*
snip
It already includes the mods, you don't need to add it separately.
Bandoliers, Jaysus Swords, and JewelCraft have been fully integrated, reducing the need for additional plugins and offering new customizable options.
This exploit kind of half works. They'll take a certain amount extra and no more. Well, they'll certainly take them and it looks like everything is ok but when you arrive somewhere else you'll find most of the extra stuff you gave them is missing from their inventory - you'll find it back where you gave it to them originally, lying on the floor. It seems the items-lying-on-the-floor only show up when you exit and subsequently re-enter the cell.
