from my tests so far the response times are actually best with "smart response" set to Off. they average about 8ms G2G from a small sample set (let me confirm from bigger sample later) which is actually very good for a VA panel. All the other settings including Fast, faster, and fastest introduce progressively larger amounts of overshoot. so thats what users are seeing when they say they actually show more ghosting. the response times are sped up, but the overshoot is horrendous as you get up to the higher settings. even at the first "fast" setting, it's pretty high. I think sticking with off is actually preferrable but let me run some more tests later
and for those who have spotted the plastic wrap on the lower bezel behind the philips plastic section, you can quite easily remove it. if you unscrew all the screws on the back of the screen the back literally just comes off, no plastic clips or anything to pop out. so if you take that off you can remove the front philips plastic section and then remove the plastic wrap easily
not hard to do at all
