- 25 Nov 2011
- The KOP
More or less everything you type is hard to process...
Getting personal Now BOYS! Touchy!
Did I mess around with your Girls or something>?
So if I was playing Borderlands 2 on AMD without PhysX you saying I am not loosing out on anything?
You be very wrong! on AMD its just like playing the console version, while with PhysX that is the proper PC version of the game.
Can I fall back onto another API? and enjoy the same experience? NO
Can You fall back onto another API on BF4 and enjoy the same experience? YES
) are rather hot
Every title with PhysX is a PhysX only title, its not like AMD have anything to full back onto is it?
With Mantle least you can fall back onto DX11 and still enjoy the game as intended by the Development..
You're talking hardware accelerated physics/PhysX.
And actually, as far as I recall, Borderlands 2 can actually run the hardware accelerated stuff on the CPU, but that's a bit moot really, as it's not really an optimal thing.
I was under the impression the *experience* between Mantle and DX11 was different, or at least, that's what you all say.
So, it's not the same experience Mantle to DX11 is it?
It can yes but you must Hack/force it to do so.. It dont work out the gate!
DX11 vs Mantle gives you the same game, the only difference is faster better performance! you dont loose out on anything other than performance.. just like running a game on a older GPU vs a Newer GPU = Better performance is the game the same game? Yes
Does BL2 support any other type of PhysX?? from the menu? No
Because it is a part of the VESA standard 1.2a (albeit an optional part at the moment, but probably will be non optional in a future revision) the answer is most likely YES.
I will ignore the childish comments about my Daughters but will respond to this.
So if I was playing Battlefield 4 on nVidia without Mantle, are you saying I am not "losing" out on anything?
You would be very wrong, as the times I have read you saying that Mantle brings a different level of smoothness and Humbug was saying the same, obviously guys without G-Sync and running AMD are missing out and getting console like performance!
Girls Being all your Nbots on here.. You seem to be the ring leader! Its quite funny how fast they all come out the wood work to support you master!
Apart from Mantle giving you faster frame latency and better performance. You still playing the same game, interacting with the same game.. PhysX only title you loose out on that interactive when you using AMD!
Nbots, hmm.
Is that a derogative term you've made up for people who have different opinions from yourself?
Do you need to own an Nvidia card to be part of that club? Or just hold a different view?
