Sucks checked when I posting and it was instock.
That was like opening a present and finding out its yet another pair of socks kinda disappointment right there
Google play has 32gb back in stock but I'm sure its cheaper else where.
On other note 5.0.1 is better but its still has some memory issues, I don't have any of the bugs I had before expect WiFi randomly disconnecting and won't re-connect unless I do it manual. Its not the biggest issue since I have 4G but a tad annoying.
Going to be annoying going forward, nothing else in the android scene matches my needs, if only google had a 2014 Nexus 5. I currently brought a z3 for a family member and I've been using it, Sony's skin in generally is ok, still ugly compared to stock Android. Its smooth enough too, but again not as good as stock Android, battery is great, its a tad too tall thou which is annoying.
So the search for an Android phone goes on...who would've thought that I'd be scrambling back to the Nexus 5...if only I can find one!!! Now that's the hassle that I'm facing.
Expansys have the white 32gb at 279 if its any good?
Mate the stock on Google Play is erratic as soon as stock comes in it disappears quickly.
Will continue hunting elsewhere but it seems that Expansys is my only option for now.
I agree with you in regards to the android scene at the moment.
I have a Z3 as well and it is superb in the battery life department, fast and fluid but like you said not as fast as stock and Sony's skin is dated and needs to be refreshed.
If only Google did bring out a 2014 Nexus 5 that would've been ideal and I tried the Moto X 2014 but that IMO didnt really give me a great experience as the screen was extremely over saturated and got on my nerves plus the call quality was below pat.
Still love my nexus 5. Think I will most likely skip the 6 and look for the 7/2015 version.
Anyone else having trouble with the latest update? It worked fine for about a week, but now the phone is frustratingly slow to the point where I have to restart it a couple of times a day.
I've not installed any new apps or anything, so can't understand what is causing it.![]()
Thanks Mate good shout but I'm very dubious buying from them. They haven't got the best reputation going.
Just picked up a black 32GB from the bay including official Nexus wireless charger, official bumper and a screen protector for 270.
A little steep but am pleased...will be back using a N5 again![]()
http://www.androidpolice.com/2014/1...fixed-after-over-1750-stars-in-issue-tracker/
Finally seems like they've sorted it.
I don't think that's too bad! I'm going to hold out hope on the play store. Crazy though ... my first nexus 5 I ordered a year ago. Seems wrong to be ordering another at the same price a year on, but I've found nothing that comes close to its out of the box experience for speed etc.![]()
Thanks Mate. It's definitely crazy though, I'm in the same boat, I've bought and sold four Nexus 5 phones since it was released and I've bought another. It does seem wrong to order at the same price but you hit the nail on the head when you said that nothing comes close to it for that out of the box experience.
I'll be reverting mine (when I get it) back to 4.4.4 and wait for all the bugs to be ironed out prior to updating to Lollipop.
Are you waiting for stock to appear on the play store or have you sourced the N5 from elsewhere?
I'm going to go out and say it. I have no Idea why people are whinging about Andriod 5.
I upgraded when I had the OTA and its been fast and faultless since.
I just don't get it
.I've wiped and install my 5.0 and then wiped and installed 5.0.1 still having issues here.
Honestly - I'm tempted to just order a s5 from voda given they are so cheap currently and be done with it! You never know when stock will show up again for the n5 and undoubtedly when it does i'll miss it!
Same issues, or different ones?
