Don't know hence my initial question, I was thinking of heating it (the solenoid) with a heat gun but don't want to damage the internals,that said, a bottle of petrol and a match is tempting at the moment!![]()
Started fitting Powerflex polybushes to my 2nd set of wishbones ready for fitting when the weather brightens up...managed an entire one bush before rage quitting...need to borrow a proper bench vice![]()
In time
BMW Business CD at present but I have this on order:
http://robbiekhan.co.uk/root/temp/Andrive08-500x500.jpg
It's the Android 4.2 powered AN46-3, like Dynavin but geared toward Android devices as opposed to Apple. Capacitive glass screen too unlike slower older non glass screens.
in process of doing mine i bought 2x lower wishbones to debush and powerflex, got the driver side fitted in the snow, took 2 days as i needed to cut through a lot of bolts and this was the first time doing this sort of thing, came to do the passenger side and got it all cut and in pieces and when i went to fit the new lower wishbone... i found it was bent and would not fit so got a honda s2000 in pieces looking very sorry for itself.
now when the new wishbone comes friday hopefully, got to debush it de-rust and paint and hopefully will go straight on
What method did you use to get the bushes out? At the minute I'm just cutting them out as much as possible and bashing with a hammer but it's really hard work, considering borrowing a blow lamp to burn them out!
It almost looks like a torx head inside, is this an option as it looks fine from that perspective? God knows what size that'll be on a 32mm head though.
The torx head your looking at isn't what I'm trying to remove, its the long silver thing to the right, the threaded nut is directly above the "3" of the "3/2" you can see in the picture.
