Okay sorry for chatting on a bit today. (Thread seems quiet tonight sorry if that's my fault
) but anyway this kayfun v4, like I said earlier I wish I'd of left the air flow as stock cause it was working, I think iv found that spot again but, the flavour and sensation per breath of vape, at the moment now Iv got over the hype of a new toy and come to reality, the flavour isn't as good as my protank2 mini, clouds are around the same, juice wise, as you may remember I ususally do around 40ml per day on cheap 8 pound per 100ml liquid, but lately Iv cut back to around 15-20ml per day untill today this kayfun has eaten juice Iv used 60ml ish,
I think I do need to spend more time perfecting this kayfun v4 because I can honestly tell it has potential, though Im the sort of person to give up too easy and go back to the last best setting like a system restore, the v4 is a 200% improvement over the 3.1.
Here's how my stats come out from the 4 tanks Iv ever used
Iclear 16 - good starter when quitting smoking when it's included with a battery for 3 pound off the market, don't get ripped off in a corner shop for 20 quid.
Pro tank 2 mini, amazing, flavour is the best Iv tasted, vapor always there. 30 seconds it takes to rebuild a coil but the unit is so small you need to make a new coil per day because it will go foul when trying to use it like a big tank for 24/7 vaping and you need to fill it up all the time but that's a small price to pay for the flavour and constant consistent vape and no dry hits no floods no nothing
Kayfun 3.1 It was good when it worked but 70% of the time it didn't, 25% of time was a dry hit, 25% flood, 25% leaking 25% working, If I spent the time to make it work im sure it would have been great but I ran out of patience.
Kayfun v4. Cloud production when it's working is better than pro tank 2 mini, not as easy to make coils for that constantly work no matter what, it's about a 3 min cool build compaired to 30'seconds. But when it's working its great, clouds are there. Taste and flavour it's different it had that kayfun taste to it even after a wash in boiling hot water, it doesn't taste as good as my pro tank by half.
It has the features and customisation definately. And it definately needs the time putting in to make it work 100% and if it works out of the box don't mess with the air flow you will spend hours taking the 510 screw out to adjust the airflow sxrew to make it work.
