Watercooled Case Gallery
Lighting is important, Looks like low light and long exposure to me, But I'm not so experienced with photography to be able to tell, So thought I'd ask
I suppose I should have asked about 'setup' over 'settings'
Can someone guess what size tubing is used in these builds?
12mm OD or 16mm OD.
This one is actually 13mm tubing
https://www.overclockers.co.uk/showproduct.php?prodid=WC-145-PM
That's the stuff.
Shawy what sort of temp are you getting in your setup?
I once thought to put two 240mm in the same way like you put your 4 120mm,but i didn't do it in the end cos I figured I wouldn't get enough airflow through it.
Thought I would share some pics of my recently purchased card.
For those interested, I'm seeing low 20's idle and high 30's load, sometimes creeps into the 40's during longer session. In the loop is a triple EK rad and a quad, the CPU is a 5960X.
My WC rig finally fully built :) Here's a few pic's
I took my time building this one and went with a fairly "minimalistic" and smart approach. I'm very happy with it. Also runs like a DREAM ! :D
Idle temps of my 2500k @4Ghz 26c and the GTX Titan at 25c. Need to get some benchmarks going will most likely do them next weekend though.
just came across this browsing, is that the bitfenix shinobi? have the case myself and struggling to figure out what options i have to watercool. wonder if you could help me if your case is actually the shinobi :)
