- 16 Oct 2003
- West Sussex
Very nice piece of kit indeed! They sound lovely on full throttle!
New discs and shocks all round? Sound like a really well-kept example :/I'll add some more pics when I get it back, currently having some work done back at Car Giant after I noticed a few mechanical faults/noises.
Apparently they are changing..
Following our telephone conversation, we currently have the following parts on order; front and rear discs and pads, front and rear shock absorbers, top mounts and front drop links.
I bought the car 2 weeks ago, reported the problem after a week, we dropped it off on Tuesday and expect it back by Saturday.
Anyone recommend where I can get some decent alloys from? These come with the bob standard looking ones, I want the ones the E Class uses.
We recently acquired W204 C200 2.2 CDI Auto from Car Giant.
Previous to this we had a C180 Kompressor 1.8 Petrol Manual, but this is much better.
Hi many miles has it done? I'm surprised it needs that much replacing, my dads same age same spec (except manual) one has done 140k miles and has only really needed the usual consumables, it still on its original clutch.
As for wheels, look at eBay. Make sure they will fit the W204 as the E could well have different offset.
Sl400 AMG ordered. Coming in a few weeks!
[TW]Fox;27489729 said:That is the fastest build of a new car ever - did you order it from stock or something?
As for the service plan it seems very expensive - you need to work out exactly what it covers and exactly how much that would cost you yourself. You may find unless you do big miles it isnt worth it.
£1476 for 3 services sounds like excellent value to me?![]()
[TW]Fox;27489924 said:It's crap value on a brand new car - for comparison sake 5 years of servicing on a 650i is £525 and 5 years of servicing on a 740d is included in the price of the car. Heck even an M6 GranCoupe is £1050 for 5 years!
This is where Mercedes always falls down for me, the aftermarket costs are very expensive.
On a car that will never be more than 3 years old when covered £500 a service is ridiculous - it'll cover 40k miles or less and should not be in need of any major work.
I think my C200 has these alloys below, very ordinary.
http://www.autotrader.co.uk/classified/advert/201409107284601/
Does anyone know what these alloys below are called or if there is some sort of variant I need to be looking for? Or, if you can find similar on eBay that would be great.
http://www.autotrader.co.uk/classified/advert/201501140163746/
http://www.autotrader.co.uk/classified/advert/201409297802431/
As that other ad says, the current size of alloys on at the moment are 16", it should be ok to fit 17" alloys onto the car, right?
