- 14 Dec 2013
Was that an easy job? I've read that the sensor for the e46 is in the pipe between the radiator and engine.
Thats not the sensor he's on about. He is on about the level sensor in the expansion tank.
It's easy to do on the E46 for a mechanic or keen Diyer.
As pepsilol says it was straight forward. Just drain the coolant, replace sensor and refill and bleed coolant system. Didn't take long and the part was not expensive either, as I said that was a 5 series but e46 3 series should not be much different.
this ******* car.
I think the worst bit was the radiator itself at around £80-90 and then the expansion tank at around £25-30.
