Use the Optical link from your soundcard ( if you have one ). Also soundcard needs to support the convert to Dolby Digital or DTS otherwise your sound will be stereo.
Its how i use my amp.
Thank you will have a look into that
There's nothing wrong with the matte monitors I have, it's just a side by side, I find monitors with an AG coating to be less sharp and grainy.
It sounds like you have glass fronted monitors to me though, a monitor without an AG coating really shouldn't be reflecting everything in them. My gloss monitors are only reflecting things when they're off.
Have you got the brightness down low?
I don't notice any serious reflections on mine unless it is off. I find the mild gloss coating to look superior than the matte mist effect given off by my Dell U3011.
Can a single GTX970 run Elite on this monitor smooth. Or will I need to go Sli. On the fence about buying one.
Hmmmmmm interesting, can you see ANY reflection in it though ? Perhaps the room light ?
Mine has arrived, happy days !
Small thing, the monitor comes with a European "kettle lead" power lead, not a UK one. We had plenty in the office so not an issue, but could be frustrating if you don't.
I haven't managed to get it out of 1920x1200 mode yet either (HDMI)
The screen isn't that reflective, more of a "sheen" than a reflection. Perhaps for those doing graphic design it may not be perfect, but for other applications it's not an issue.
Enjoy!
Pretty sure mine came with Uk plug. But if not, I may not have cared enough to take note as I have sooooooo many spare cables lying around.
Don't think you will get more than 1920x1200 over hdmi. I could be wrong and maybe it will allow up to 2560x1440.
Certainly creating a custom resolution should work fine.
