Caporegime
- 7 Apr 2008
- Lorville - Hurston
i have 12gb ddr3 ram and a 5670 xeon that are no use to me now
So how much have you laid out then mate for your X99 setup.
EDIT: just seen the deal in MM, well that's a good price for that lot. Done well.
Only problem is warranty buying second hand if it goes up in smoke your not covered. Sure you'll be fine though. My gigabyte board is going strong 6 years on.
Seem's odd he was selling that lot as it's so new?
Noticed you went for a 5930K which I know is a bit more expensive, but to be honest it's the cpu I would/will go for.
I'll be quite interested in your thoughts about X99.
Many of the people who bought X99 won't have it very long. It's a common thing.. Something new comes out, gotta have it, will improve my life etc, then the penny drops and they come back to reality and sell it on and replace it with a normal sort of set up.
The amount of times I've seen Boom humming and harring over whether to sell his.
The actual amount of people who sit down and weigh things up and buy the actual rig they need is far lower. X99 is basically a cheap way to build a professional workstation without paying Xeon money. That's its sole purpose yet people buy it to run benchmarks and games on.
When I spent three grand on my rig I knew it was a very long term investment. I sit here every day fully expecting it to go for five years or so without me even needing to do anything but blow the dust out of it once in a while (usually every month or so).
But I didn't buy mine for gaming. I bought it so I can do what I love and that's coding front ends for an emulator my friend wrote. I sometimes go for months without doing it, but, I always go back and when I do I find the extra power makes things much easier for me.
X99 is a very big investment but, can actually work out cheaper in the long run that either buying a new rig every year or so or spending £500 every year or so on upgrades. You just need a big old pot of anti itch cream and it's worth the investment
Same goes for my Titan Blacks. They were a hell of a lot cheaper than Teslas !
i just dont game on my pc. i am a coder and a photographer.
infact, i use my PC more for coding and photography, less for gaming
You just need a big old pot of anti itch cream and it's worth the investment![]()
I got some good deals..
Basically
£350 5930K
£100 X99 Gaming 5
£150 DDR 4 Corsair 2800mhz
Total £600
I'm happy with the cost of the upgrade...Sold my MOBO already and 6GB ram
So I reckon after I sell the rest.. Chip, soundcard...I'm looking at around £345 for my new PC
All used or is the ram new?I got some good deals..
Basically
£350 5930K
£100 X99 Gaming 5
Total £600
Basically
£350 5930K
£100 X99 Gaming 5
Total £600
Well the ram is a good price, paid about 60 for 8gb of ddr3, so 150 for 16gb 2800mhz ddr4 is pretty decent.
Considering I needed to get 3 x 4 gb DDR3 if I was to keep my x58 anyway...![]()
He got it from the same thread dude![]()
I see, all second hand then!
On a side note I've made a thread in the wanted section of the MM for X99 parts!
Hoping to get lucky too!
I never bought used hardware until about a year ago. My GPU blew up and I wanted an AMD replacement (to spite nVidia's decision to not fix a crash affecting all of their DX10 cards in Source engine games) but the choice was either paying more than I wanted to, or buying old tech. So I went used instead and I'm glad I did.Might consider doing the same, but maybe only for the ram.. i usually never buy used hardware.
Interesting rig
gets the same as a 5820K clocked to 4.5 ish ghz....
You may as well set the multiplier as high as you can so you can reduce BCLK to avoid strain on other components.I've just jumped on the Xeon 5650 bandwagon too, got it running at 4.4 (220 x20). Has anyone experimented with the different multis much regarding which one would offer the higher possible clocks? Just curious if i could get a bit more out of it or if i should just be happy with what i have.
From what I have heard multipliers with Odd numbers requires less voltages. so you could try 19 or 21.I've just jumped on the Xeon 5650 bandwagon too, got it running at 4.4 (220 x20). Has anyone experimented with the different multis much regarding which one would offer the higher possible clocks? Just curious if i could get a bit more out of it or if i should just be happy with what i have.
