I see no strings? How did you make it hover like that![]()
With my Mantle Force powers.
AMD cards are so advanced now that the cards can use wireless power delivery as demonstrated in the pic.
May the
A GTX970 does have 4GB of VRAM, so what's the problem ?
It's the way the VRAM is implemented. It's done in a way that wasn't mentioned by the manufacturer or the retailers. It may not make much difference, but the 3.5GB + 0.5GB does make a difference that wasn't mentioned.
If graphics cards manufacturers are going to partition VRAM, customers should be told, especially if it has an impact on performance in certain situations.
The difference between a 970 and a 290X power draw wise is the same as an old fashioned light bulb.
Do you game in the dark ?
No but I game without sweating now. lol Light bulbs are fine where they are, on the ceiling.
In all of this long protracted ordeal this is still the single most absurd point being brought up.
And if you all take a little longer than 5 seconds to think about it you'll quickly figure out why .................
Please, spell it out for those os dim/drunk/half asleep/of a completely different opinion.
Share your thoughts rather than..............
I`ve had a think for much more than 5 seconds, and I still can't figure out why the point I made is absurd.
Please enlighten me.
Because the cards memory is basically useless beyond 3.5, why isnt that specified?
I'll give you one of many examples.
An AMD 295x2. Its listed as having 8GBs of Vram , Physically yes it does , can it use all of it ? yes it can, however you go north of 4gb vram usage and its all going to go boobies up.
Isn't that effectively a crossfire setup on a single card ?
My understanding is that in a dual card setup, the combined memory doesn't perform like it would if it were on a single card.
