Teeth mod tested now for 4 hours and definitely improves lip sync massively over vanilla. Its not perfect and occasionally it wont sync immediately but usually does by the end of the conversation. For the most part its great. I use the two 1k options below:
http://www.nexusmods.com/skyrim/mods/53237/?
http://www.nexusmods.com/skyrim/mods/56497/?
Does anyone know if there was ever a fix for the quick reflexes bug? Usually I just avoid the perk, but would be great to see a fix.
Who was accusing anyone of lying? Appologies I just posted my experience no offence meant. To be fair I havent tried them with enboost yet. The occasional pauses im on about are when transversing the landscape and moving across cells. I just used to get a slight pause occasionally vs none on 1k.
What other mods are you using?
I run 4k/8k textures on SLI 680's and my game runs smooth but down to having my game and mods on an SSD as well. Loading them is smooth.
Are you running the unofficial patches and recommended fixes in the OP?
Guessing you installed the mods manually as well?
Yes I do.![]()
Does it benefit your game in anyway? As I can't seem to find a video to show it
I've only been using it for the past couple of weeks. But basically it applies the SKSE memory block allocation fix, but without the need for SKSE. So for my current mod build I'm rolling with, it gives me an alternative to not having to use SKSE.
I did read that once you use the memory block allocation fix then using enboost may help further to cope with the additional memory allocation that you've enabled with SSME. Hence why I'm now also running enboost too. So far no issues whatsoever and all is running great. But it is early days for me.
Just make sure you set the ini for SKSE correctly and yep you dont need ssme![]()
I'm pretty much decided to stop tinkering and get on with playing!
